prop carrosion
hey guys, any ideas why my stainless steel props are corroding. the boat was in the water about two months but it was fresh water. thought stainless was stainless
Best Answer
elarson5757
Member Posts: 232 ✭✭
Although it may be making it worse..the B3 is known for the slow speed constant back and forth wander. Mine is gone after adding trim tabs and I put them all the way down at slow no wake speeds...tboat said:thanks. that might be why it was hard to keep straight at no wake speed.
Without them it was constant back and forth steering to keep it straight...
My my metallurgical seminar for the day. lol
Are your engines operating in their proper wide open throttle (wot) range. If not, it could be due to prop misalignment, poor hubs, etc. which could cause cavitation (bubbles along the prop blade surfaces) which can quickly erode the props.
Scaling is a thin, rough coating that typically develops on freshwater SS props from the combination of anodes and a Mercathode system. You can remove it with mechanical action (sanding) or (some say) a strong scale remover such as Lime-Away (which has never worked for me).
Corrosion would only happen if something is badly wrong with your corrosion protection system.
Thanks Raybo
A quality prop shop should be able to weld repair and tune the blades. Look for someone near you with a Prop Scan device.
Also, when you put the blades on, make sure you use the Mercury 2-4-C grease on the splines!
Paul
06 Rinker 270
