Anything negative about this eBay thru hull fitting
Most places seem thru hulls are at least $25 and up.
I found this on eBay for $19.
http://m.ebay.com/itm/161493242509
Seems to be fine.
    I agree that the prices are low. 3/4 bronze whether barbed or screw-on is usually in the $35 range. I noticed on your link that the SS was way cheaper too. Bronze comes in different compositions that can significantly affect its durability. The part you've found may be a great deal or junk from China. I can't tell. It IS a through hull though and might be worth making sure that the quality was there.
    Use 5200, its always a thrill to drill a hole in your boat.
    ...try drilling two 4 inch cut-outs in the transom for through hull exhausts after measuring the locations 50 times and hoping you were right, LOL!
