Tune Up Mercrusier 350 MPI Horizon
onislandtime
Member Posts: 309 ✭✭✭
Want to get advice from Captains on tuneups for their engines. What spark plugs, distributor cap and rotors you use. This will be the first time I do a tune up.
Sold at west or your local boat store slash dealer.
Be extremely careful when installing the cap. You can easily break the tabs where it screws into. Ask me how I know. BTW of you do: $900 to replace the distributor.
The question is what "specific" spark plugs, distributor and rotor "do it yourself" Owners/Captains use for my particular engines. I am a big supported in using marine grade products as they are made to last longer in the marine environment.
-Spark Plugs: A/C Delco 41-933(original plugs A/C Delco 41-932 were discontinued and superseded by 41-933)
Too start "yes" automotive parts are the same except for one important aspect, Marine Starters, Alternators, Distributor caps, Rotors, Spark plugs, Fuel lines, Fuel pumps etc are CG approved because they are sealed and tested to prevent sparks.
Another piece of information I ran across while researching. The number one cause of explosions on boats are from "non" CG approved parts and poor ventilation (non working blower or not turned on). Second was not inspecting for leaks in the engine bay prior to engine.
So if you don't find any fuel leaks and or develop one while underway and use your blower, you may get away from blowing up your passengers so you can save $50! lol
A do it yourself tune up for twin engines (Distributor Cap,Rotor,Spark Plugs) would cost you about $200 every 3 years vs $130 to $150 with Automotive parts. (If the Automitive parts last 3 years in your marine environment)
Anyone else have to use the Q06 FWC size belt and know the gates alternative?
http://www.marineengine.com/parts/mercury-quicksilver/application-guides/mercruiser-v-belts-and-serpentine-belts.htm
www.dormanproducts.com/p-53495-90449.aspx
