Hurricane prep
MDboater
Member Posts: 298 ✭✭✭
First and foremost, I hope that all of the forum member are doing well in the wake of hurricane Matthew. Some recent photos from the Carolinas showed the common post hurricane pile of boats. I am interested to hear what others consider to be the best boat preparations when threatened with a hurricane. Specifically would you leave your boat in the water or haul it out? If in the water, would you rather be tied to a floating dock, a fixed dock, a mooring buoy, or other?
Well, I've had a boat in the water the last 17 years in MD, and I've never rode one out. There are plenty of places around here that can also pull your boat out. Surge has mostly been the issue for hurricanes here in MD. So, if you are in a marina that has floating docks with really high pilings (at least 10-12 feet over high tide), then that may be ok, depending on what else is around you. I've had my first boat on a trailer thru big hurricanes such as Isabel. I remember walking around the day after at many marinas. Surge was the worst and ruined a lot of marinas. Most boats on lifts did fine. My second and third boats have all been on lifts thru the MD storms/hurricanes. Wind gusts weren't the biggest concern, again it was surge. So, for me, I'd leave my boat on the lift cause I can raise my boat 10 feet up over high tide (& my dock/slip all made it thru Isabel with a different boat on it).
Now, with that said, if you can have your boat hauled and stored at least 8-10 feet above high tide, then do that and strap it down (although I'm not sure if anywhere around has the ability to strap it down).
In some marinas, even if the pilings are really tall, the breakwaters aren't. Once the surge submerges the breakwaters, the waves can come rolling right into the marina like Lawrence Taylor in search of Joe Theismann. That's when the real damage happens.
Nobody wants to lose there boat, but if is tied up at the marina, and gets destroyed. Doesn't the insurance wright you a check ?
If so, insurance company's have big tab to pay.
