2004 270 FV - lets talk about the anchor locker..
My rear bilge STINKS! Like a serious nasty as heck stink. Rotten eggs, manure, sulfur, the worst smell you could ever think of...that's it!
I've tried bilge cleaner ( a GALLON of it )....the only thing in the holding tank is chemical (I've pumped it out and put JUST chemical in there). I've removed the hot water heater....the front bilge where the a/c is does not smell.
I spent 4 hours replacing batteries today and at the same time scrubbing the heck out of my rear bilge. From what I can see there is some seriously BLACK water back there and sludge as well.
These pictures are taken at various stages of cleaning:
https://goo.gl/photos/sNv2jFXmqyq6wMcy9
What you can see is at some point there was some nasty crap down there. When I hit that stuff with the hose it released the same smell but 10 times worse then I've ever smelled it.
I easily put 100 gallons of water down into it today and pumped it out with the bilge pump as well as me manually pumping it out with a manual pump.
So the question is: Where the heck is all this nasty stuff coming from??
What I'm hoping someone knows is.... If the front anchor locker drain IS NOT WORKING... is there any possibility that all that nasty MUDDY water that comes up on the anchor line could be getting from the front anchor locker to the rear bilge...bypassing the front bilge where the A/C is ?
I figure maybe there's a channel under everything else??
I plan to empty the anchor locker tomorrow morning at the dock and use a hose and red food coloring to see if this theory might be right... I just don't know where else nasty dirty water would be coming from?
I can't see how.......I had all the rope out to measure and clean mine, in the spring, and washed it out good. No water appeared anywhere, and by looking in it, it appears sealed other than the drains.
A/C does drain into rear bilge not front, atleast on my 05. I wonder about using a cleaner with bleach in it. My bilge didn't smell, but I did try to clean it with several cleaners, and wasn't impressed with any of them.....probably because they are for marine use? I'm gonna do a better job this winter on land with the plug out
Keep in mind this boat has a brand new motor (20 hours on it) and brand new transom mount/housing..
I put some bilge cleaner down there and scrubbed with a brush, seemed to get rid of the smell for the rest of the day, just concerned about where it came from to begin with. the hoses all look new and the tank has something written on it with a date from 2010.
I'm going to vacuum it back out again on Wed, cover it and see what happens when I get back to the boat Saturday.
MD, there are several hundred boats in my marina on lifts and not one pulls the plug each weekend. Just too much of a pain.
Handy, yes it's rain water in there as well that I vacuum out.
What I did do, is took my raw water pump and disconnected from the seacock (since I don't use the raw water to wash out my cockpit). Ran a hose down and added a npt fitting on the end and have it right down in the drain plug dip. Now, I just turn that pump on and drawl all the water out of my bilge any time I need to. Works like a champ and at the flip of a switch I have a dry bilge!
