Fuel filters
Are there any other fuel filters besides the main fuel filter on a 5.7? The main filter was changed last week but today on the way back from an overnight stay I noticed some surging at high RPM's. If I backed off the throttle a little bit the surging went away.
or..
the fuel pump gets it's energy from the starter solenoid on start-up only, and then it goes to the hot 'keyed' wire.. it's purple.. it could be that the hot purple wire is shorting due to corrosion or bad connection at the connection points, which would limit constant voltage to it.. and cause a condition like you describe. Give that wire a look-see from the key all the way back, and make sure it's connected well, and corrosion free...
good luck!!
I forgot that your engine was out.. honestly, that leads me more to believe there is a bad connection somewhere.. those things happen on install..
Check your grounds.. closely.. check your power leads from alt and battery.. check harnesses, especially to the thunderbolt ignition.. get some dielectric grease and slap it on the fittings/plugs.. anything wired, check its seat.. its a six pack job is all, meaning the last one will be draining whilst you reseat your last connection..
If your tank is full of junk, you can thank your filters for protecting your engine.. swap em', friend..
If you gotta start with fresh fuel and get contaminants out, that's what you gotta do.. it may behoove you to figure out what's clogging them.. cut open the old one and see.. I'm curious, too.. also, though: a new filter does not restrict as a used one, which makes the pump work harder.. an aging pump loses pressure because its fighting.. they usually literally burn themselves out.. some OEM go so far as to submerge pumps (in fuel) to keep them cool.. it could still be your pump.
