4 batteries and a 3 bank charger
All (first post, pls be kind),
New (to me) 2006 342 EC has 4 batteries and a prosport 3 bank charger. Does anyone else have this configuration or was it an addition later? Am watching the house batteries just sort of bleed out and I don't want to replace the batteries until I understand how the system should work correctly. Is there any way the charger could be charging all the batteries? Was thinking that it made sense to be charging the cranking batteries and one of the house batteries, but as I think of it, it might make sense to keep only one of the cranking batteries under the battery tending and both house batteries. Not having a true wiring diagram is driving my crazy.
symptoms: with decent 110V and the battery charger energized, the house won't charge even with just the dc main and no load (that I know of).
am thinking that the logical troubleshooting order would be 1) batteries, 2) charger circuit, 3) load or other shorts
thanks gang
thanks gang
The two house batteries are connected together in parallel, so the charger just sees them as a single large battery. That's the standard configuration.
I'm sure you've already checked that the cable connections are all clean and tight. Check the water levels in the house batteries. If they are low, top them off with distilled water and see if that helps.
Also, try to find out how old the batteries are (from the dates on the stickers, or maybe from the previous owner's records). Conventional flooded batteries are lasting 3-4 years for most people here.
I ran the engines and the generator for several minutes and switched to generator power just to check what worked and didn't. With the engines running, DC shows 12.5 to 13V which is what I expected. After shifting back to shore power and shutting down, Volts are steady at 12.5. Somethings whacky. I realize that the battery tender will go through charge cycles, but I can't figure out what would have drained so steadily before.
The "typical" wiring diagram is insufficient for the 342s with a 3 output tender, a generator, 4 batteries and two electrical isolation switches (one for Gen, one for the cranking batteries (1,2,both, off). Who is the Electrical wiz kid in this neighborhood?
Other symptoms: Tundra cabin Frig is intermittent. Seems to need 12V event when it is running off of shore power. Could that be true?
Shower sump doesn't seem to be getting any power at all. Anyone know how it's wired? I saw the cb, but it have a switch? need DC main? Draw of the same circuit as the fresh water pump? I'm gonna be on a bug hunt for a while.
As far a shower sump, did you actually check the wires to see if it has power and not just a broken sump? I would imagine it's wired directly to the main panel.
I checked the leads and they say 12v, but under any load they collapse. Tested the pump on a 12v power source. Checks 4.0. There are a couple of leads that look to be repaired, so I think I'm going to have to start tracing wires.
The shower sump doesn't have a separate switch.
