OIL CHANGE TIME
OH, HAPPY DAY!!!! I always knew my transom plug had a little cable attached to it (keeps it from getting dropped/forgotten) and there were some discussions that this was attached to a tube from the oil pan. After some groveling around on the concrete and getting some good light on the situation and fishing around with a steel rod and coaxing the darn thing a bit, I was indeed able to pull the oil drain tube out through the hole. YEA!! No more sucking oil up the dipstick tube, and not getting it all. I am SO Happy!!!
@randy56 good points! Most marinas run it for 5 minutes if you're lucky.
Way back in 1990s we ran the engines (carbed) to normal operating temperatures then poured fogging oil right gown the carb until the engine stalled. No more of that now with the EPA and clean marina designations.
With EFIs/MPIs I gave my engines a good ten minutes to reach operating temperature - this is at winterization as the water is a lot cooler - but I usually ran them for another 5 minutes to be sure. The oil filter and oil were too hot to handle and the valve covers were hot too.
Now with the cats the engines heat up pretty fast, but I still ran them for 10-15 minutes just to be sure.
Better safe than sorry.
In the summer with warmer water I ran them 15 minutes for sure then let them sit to drain down.
