oil change in fall vs spring
skennelly
Member Posts: 2,196 ✭✭✭✭
With my winterizing routine I always change the engine oil in the fall.
This past weekend I went to my storage facility to winterize only to find out they have winterized their buildings already.
This means I could not run the engine of muffs to warm it up to change the oil.
So for the first time I'm going to leave it to the Spring and change the oil then.
How bad is it leaving old oil in the engine over winter?
make sure to warm up the engine before oil change.
i have done spring service and fall service and end resUlt is the same.
but more to the point: ash is acidic. suspended in the oil and the oil in rest it will have it's way with it, altering it's pH. The point of filtering it is to remove the stuff and trap it in media that is made of material that neutralizes it's impact to the compounds and structure of the oil..... so... when you're going to let it sit a long time, you want to have fresh oil with a high moly count- such as that for a classic car, as well as an dispersant so water doesn't chase the oil off hard parts and doesn't clump.
during the season, you'd rather attack it differently- you're not as concerned with dispersing the insolubles because the filter will collect it, and emulsifiers are a better plan of attack to absorb the water present instead of letting it collect and rest against metals- to be evap'd when the engine runs.
but all of this is just to mess with you... all oils that match the prescribed rating will be fine in there over the months to come and will do what they're intended to do in your absence.
lol
