Transponder advice
davidbrooks
Member Posts: 1,418 ✭✭✭✭
Need some advice here. I am driving myself crazy with trying to match up the specs. I have a 2003 Rinker 342. Just got it this year and it was really well maintained by the previous owner. So i am thinking that the dash needs a Fishfinder. I was going to put in the SIMRAD GO5XSE ($419) above the Garmin. It would provide a nice backup in case the Garmin went out. Additionally i could interface the engines into the GO5 at some point. So I am really wrestling with what transponder to pair with it. I think i have ruled out transom mounted so that leaves through hull or in hull. My first choice is in hull as it would also give me temp but i could be swayed. Deadrise is 22 deg. Fishing would mostly be in the Chesapeake bay (6ft to 100Ft). In hull, through hull, low, med or hi frequency, plastic, Stainless, brass and i was really hoping not to break the bank. Just looking forward to using the new chirp technology. Can anyone help?
Thanks,
David
Thanks,
David
Best Answers
Handymans342
Member Posts: 10,375 ✭✭✭✭✭
I cant give you a model number for the transponder because it has to match your electronics.
"teak" that is glued down. Sandable if you get something on it. Supposedly it doesn't get too hot. Have to wait till next summer on that one.
Going to put the hole above the water line, under the swim platform and use one of these...
