Rpm gauge
planesailing
Member Posts: 173 ✭✭
I think my rpm gauge under reads by about 500 rpm but occasionally it will read what I believe is the correct rpm (500 rpm higher than it normally reads). Any ideas how I can verify this and what's the best way to fix it so that it shows an accurate reading? The boat runs perfectly but this is one of the jobs on my winter "to do" list that I hope to sort out this week. Boat is 242 fiesta vee with a 5.7 efi merc and bravo 3.
Check the back of the tach in the dash. Many have a switch for 4/6/8 cyl. Make sure it's still in the correct position. Give it a few slides to loosen any gunk that may have formed in it. Double check the connections on the tach. Make sure they are tight and you have a good ground.
Good luck
They are marked as :
STB HIGH is the starboard high RPM fine tune
PH is the port high RPM fine tune
STB 0 is the starboard low RPM or 0 adjust (you should not have to touch this one if the tach zeros at key on).
PL is the port 0 or low RPM adjust (you should not have to touch this one if the tach zeros at key on).
PRT is the Port course adjust (set to 3 for 8 cylinder)
STB is the starboard course adjust (set to 3 for 8 cylinder)
