Dipstick question
My 09 340 has twin 350's. when I check the port oil with the engines cold & then later in the day (waiting 20 minutes or so for all of the oil to drain) the oil is at the same level on the dipstick. On the starboard engine, there is sometimes a significant difference (an inch or more on the dipstick) & I'm not sure which level to trust?? Any ideas why there would be a difference? If I trust the lower amount showing on the dipstick, I'm low on oil, if I trust the higher dipstick reading, I have too much oil.
I check the oil multiple times per weekend & have decided to trust the lower reading, which happens more often, but it freaks me out when I get the occasional high reading.
Are you saying the level changes by more than an inch on the same dipstick. If so, it could be that the oil is wicking up the dipstick. So clean and measure a few times. It could take 5 or so measurements to get a good reading as the oil oculd be in the dipstick well itself.
OR
Are you saying the oil level difference between the starboard and portside engine is 1" different. If so, why would these two levels be related, unless you have some listing on your boat. One could be low and the other ok.
It's straight oil, though, right? Not a milkshake? Or chocolate fondue looking stuff? :-)
Oh... Pull your pcv valve.. shake it.. it should rattle.. if not, you may be building crank case pressure, which does the same thing to oil sometimes..
