bravo III prop nut anode kit $$$
skennelly
Member Posts: 2,196 ✭✭✭✭
Why are these kit's so expensive to retrofit an older Bravo III with a prop nut anode.
Seriously $80 for the kit that includes a new nut that accepts the anode.
Are they made of solid gold?
https://www.offshoremarineparts.com/70782m.html
This kit comes with the special nut and anode. This one is $99 but I thought I saw one for $80.
http://www.boatzincs.com/mercruiser-magnesium.html
Martyr CMPNDAF14UNS Alloy Bravo 3 Mercury Prop Nut Assembly Aluminum https://www.amazon.com/dp/B000N9FXBE/ref=cm_sw_r_cp_api_4EdGybY6RZRR7
The Amazon listing says "not recommended for freshwater"
http://www.boatzincs.com/pdfs/Which_Anodes_Should_I_Use-Chart_Merc-B.pdf
Magnesium is more expensive than Zinc or Aluminum for some reason.
