Fresh water flushing in salt water
luvinlife
                    Member Posts: 501 ✭✭✭
                    So....my new to me 2006 FV 270 (volvo 5.7) has some type of hose attachment on the engine that can be used (I believe) to run fresh water through the engine. I am not sure but I think you simply attach a hose to it and it runs water in a reverse direction through the engine and out through the outdrive. I inquired about it during the marine survey. The surveyor said the process is not very effective and that using the boat frequently is the best thing for it in salt water. Does anyone else have this hose attachment or have an opinion on whether or not I should run fresh water into it after I run the boat?
1. So if Lovin is in the water, and he hooks up the hose to the water inlet. The water pressure from the hose, turns the pump to push fresh water through the system. Salt water pushes out through the exhaust. without starting engine?
2. There would be no way to tell, if the Y pipe is filling up, and gravity/water pressure is removing salt water.
3. What is the concern about the BIII and pump location, I know where each are located. Having both. Always start my boat in the spring on muffs, to test, then fall before changing oil.
4. Sorry so many questions, someday I hope to semi-retire in the south, in the salt.
http://www.quickflushvalve.com/how-it-works.html
Andy
Andy
@andyd - awesome - another great boater mod!
