Faux teak decking on swim platform coming up, how do you re-glue this material back down?
Our marine mat teak decking is coming loose in one spot on the swim platform. What have folks used to re-glue the deck material?
Best Answers
Dream_Inn Member, Moderator Posts: 7,726 mod
I'd go with 4200 first for this application instead of 5200. Mainly because at some point, someone is going to want to remove it and replace.Dream 'Inn III -- 2008 400 Express
06Rinker270 Member Posts: 1,277 ✭✭✭
I just did the exact same thing to my teak swim platform as the teak was coming slightly up from one edge and water was getting underneath. I used UV4000 to caulk the edge to help keep water out and help keep the teak bonded to the swim platform. Waited until winter lay up so I knew it was nice and dry. Here are two links for some good info that helped me decide.
http://www.thehulltruth.com/boating-forum/477198-3m-4000-vs-4200-a.html#b
http://multimedia.3m.com/mws/media/764986O/iatd-product-info.pdf
Patrick
06 Rinker 270 -
Cableguy Greg Member Posts: 5,046 ✭✭✭✭✭
I would also use 3M 4000UV for the repair. I have found myself using 4000UV for most of the work that I have done on my boat, above and below the waterline, since it is rated for such, just like 4200 and 5200.
