Strainer O-Rings
                    2002 Rinker 342 with Kohler 5e generator. Last season, the strainer was slowly leaking into the bilge when the generator is running. I only noticed it at the end of the season and realized it was missing the O-Ring that goes in the plastic screw on cover. I told myself i would measure and figure out what size i needed but of course i never did. My boat is over an hour away from me now so i cant measure what i need to. Hoping someone here will know off hand what the part numbers are or where to get them.
I also am wanting to replace the O-ring on the AC strainer because when it was winterized last year it appeared as thou it wouldnt hurt to change out so im needing the size of that one also and i failed to get measurements off it as well.
If anyone knows what the part numbers, sizes or any information is i would greatly appreciate it.
Thanks!
Thanks!
Forespar T-150. I added the ball valve to be able to clean the strainer and not drain the water to the genny.
https://rinkerboats.vanillaforums.com/discussion/comment/64996#Comment_64996
