A/C coils keep freezing up...suggestions?
jjherber
Member Posts: 4 ✭✭
I have a 2004 270FV with a Marine Air A/C/Heat unit. This past summer, the A/C unit coils kept freezing up and blocking the air flow on the vent. Had to either use a hair dryer or turn on the heat to unfreeze...then would work fine...temporarily. When the unit is operating normally and coils not frozen up, the unit works great and will cool off the cabin nicely. Strainer is clean and unit has great water flow / stream. I'm guessing that it needs to be recharged with refrigerant...but was wondering if anyone else has experienced this problem. By the way...the screen / filter is clean and there is nothing blocking the opening to prevent airflow to the coils. Any suggestions? Thanks...Jason
I agree with calibrating the ambient sensor as well, hold the power button while the power is off, P1 will apear, move to P5 using the arrrows, adjust the temperature to the ambient temperature. Also check The setting on P8, this is the deicing cycle, ensure it is not off, default should be 1.
