De Winterize
My boat floats year round. Due to my latitude, I still have to winterize. I hired the winterization, but i want to try to put it back together myself this year. Because it floats, it's winterized differently than a boat that's out of the water or on a lift. I believe I need to; 1) Re-attach two hoses 2) Put two blue plugs back in sea water pump and third plug in lower left front of engine where water drains. Did I leave anything out? where is the extra hose clamp from?
do have both a generator and a water heater. definitely not the other end of the red hose. clamp too small.
No, it wouldn't be the red hose, it could be the black hose on the seawater pump (next to other end of red hose). Could be for generator as well. Definitely look at all seacocks.
To which black hose are you referring, Dream Inn III? I hope you can see this schematic I've attached.
