Prop pitch
Be interested to know what prop pitch some of you are using especially if you have the same set up as a me?
I see some of you are reaching the late 30s even early 40 mph top end.
I have a 270 with a Volvo 5.7GXI,
Leg is an SXD P. I don't know what pitch I have at the moment but will check when it comes out of the water on Wednesday. I'm looking for more top end.
The bottom will be clean when it goes back in so expect to get a better top end then as well
thanks in advance
thanks in advance
http://rinkerboats.vanillaforums.com/discussion/5685/4-blade-bravo-3-props
Or is there a chart to find out?
http://www.volvopenta.com/SiteCollectionDocuments/Penta/Propeller guide/Propeller Guide.pdf
http://www.pentamarine.co.th/pdf/propellers.pdf
