That time of year soon
Stodge
Member Posts: 2,738 ✭✭✭✭
I'm going to put on my Coast Guard Auxiliary hat for a minute:
It will be time to prep the boats soon. This should include checking that all your safety equipment is serviceable. Check your fire extinguishers for a good reading or unbroken seal. Check the expiration dates on flares. Look at your life vests and check for rips, tears, mildew and check their straps. If the buckles are getting chalky looking they may be brittle. Double check the covers on your batteries. Make sure those blowers are actually moving air and not just making noise. Honk the horn, look at your nav lights and get a radio check (on any channel other than 16).
If you want to have someone perform a Vessel Safety Check you can go to http://wow.uscgaux.info/content.php?unit=v-dept&category=i-want-a-vsc fill out the form, and the 5 examiners closest to the location of your boat will get an email. Someone should respond to set up a time to do your VSC.
Be safe this season.
Radio
Lights
Life jackets
Flares
Blowers
Kinda like these:
I also left out checking the backfire flame arrestor for lack of oil/sludge.
I always feel bad when I can't pass someone, but I make sure they know the effect of not having whatever it is and let them know I can come back and re-inspect as soon as they have it fixed.
Our club has a team of USCG inspectors come to the marina every spring and inspect as many boats as they can. We schedule it the same day as our spring clean-up day and pancake breakfast, so it's a well-attended event.
I just got a CO2 detector that runs on batteries and displays the CO2 level. Mine was the original which was 14 years old (shame on me).
The hardwired ones can go off if the voltage gets too low. As for testing, I'd try a candle or other controlled flame near the detector. I think the pros have CO2 in a can to test with.
@Handymans342 underwater lights can be confusing, so can any light source from a boat at night other than her nav lights.
@Cableguy Greg I agree about the ground effects. I've seen pontoons with docking light turned on when underway.
We have a gas station on land near shore that has this big LED sign. It shows all the colors in the rainbow. And it was just in my field of vision when I'd try to find the faint red and green of the markers for our marina's channel. They were supposed to put up a barrier to reduce the effect it had for folks on the water.
