Help: 320 with 5.0 VP sea trial having difficulties to be on plane at 3400 rpm
Hey guys,
A 320 with the bottom in poor condition how much would affect its performance? I see on the forums that the 320's cruises at 3400 rpm at a speed of 25 mph or so. This one needs to be at 3800 or 3900 just to be on plane and will get about 24 mph. Lower rpm than that and the boat will stall. Top speed at 4900 rpm will reach 34 mph. The bottom is in need to be painted, though. Any ideas? Is the boat too far off?
Thanks in advance.
Post edited by JLAS on
Today's test drive was better with a clean bottom. The boat got to plane with no problem at a top speed of 38 mph at (5000rpm) and cruised staying on plane at 3500rpm with tabs down, though @ 18-20 mph. Bellow that I don't think it would be able to be on plane. I still think with new bottom paint the boat will get to specs or closer to it.
Thanks, once again, for your input.
The first picture is at 27.8 MPH at about 3600 - 3700 RPM. Note that the factory tachs leave a lot to be desired when it comes to accuracy so when reading the tachs it's a bit of a guess.
This set of pictures is the "sweet spot" for my 320 - right around 32 MPH at 4000 RPM gets me around 1.2 MPG.
The second picture below was at wide open throttle which got me to 37 MPH at about 4600 RPM - I have since had it up to 42 MPH at around 4900 RPM. Note the differences in fuel burn, etc.
