thru hulls
rasbury
Member Posts: 8,741 ✭✭✭✭✭
So, have been trying to figure out a leak. Have a previous thread but when i pull up the site, it says answered so I don't know if anyone continues to look at it or not! So, I brought it home and ran it on the muffs to see if I was leaking at a hose- have closed cooling. Coupler was just replaced, I have a foot pick up and a thru hull for cooling. I checked the transom connection and it is clamped. No visible water. So, I looked at the thru hulls on the hull. The two in the from look like they have been replaced at some point, plenty of sealant around them. The two in the back for the Genny and engine cooling are very corroded and no visible sealant. I know the easy answer is replace which I will put on the list. Are they not sealed from both sides, are they likely to leak in this condition?
Mine were on a 270 for toilet and ac
The actual thru hull should have a nut on the inside and seal would be something like 3m 4200 or 5200. I chose 5200.
