Can Synthetic oil cause oil leaks?
                    Hey guys,
I have Volvos 5.0 on my 320, and am about to make an oil change. Apparently, the previous owner has been using Quicksilver 25-40. I would like to make a change and Mobil 1 Synthetic 15-50. The guys at the shop where I got the oil told me that often synthetic oils will cause a motor that has been using conventional oil to leak. Has anyone experienced that? Should I continue with the Quicksilver brand?
Thanks in advance.
Thanks in advance.
Seems like a lot of folks agree that if you have equipment that is around 10 years old or has lots of miles (or in a boat's case - lots of hours) that using synthetic will cause older seals to start leaking. Most companies that make synthetic oils say that they design the molecules, etc. to create less friction, fill gaps and things like that. What they don't mention is the potential negative impact to older or high mileage equipment seals.
If it were me, I'd stick with a known good scenario and stick with the conventional at this point. If you were dealing with a newer boat then synthetic would be a good option. I've had my 2008 320 since new and have always used the conventional engine oil recommended by Mercury Marine.
Andy
