2005 342 ,, 5.7 with XDP outdrives , I want to change my water intakes to thru hull
2005 342 with XDP out drives , 5.7 engines , I want to change to thru hull water intakes . Two reasons , 1. I run in shall water often and the XDP water pick up is in the front of the unit, I tend to take in silt into my heat exchangers. 2. I want to remove the water hose by the bellows to give more room for the bellows , I already have a 1 inch intake for the gen, I could tee it and run a hose from there around the engine to the power steering cooler on the port engine. I would want another 1 inch thru hull with strainer to power steering cooler on starboard engine . Then remove the water hose from the lower unit to transom shield .
So can this be done ? will it work ? where to drill thru hull for second pick up ?
thanks rick
thanks rick
My water on the XDP pick up is on the very front of outdrive , goes thru outdrive to a 1 inch I.D. hose from top of drive to transom shield { this hose I want to remove } .Then short hose from inside of shield to power steer cooler . I have no strainers .
Regarding the below pic, circle 1 is the Y for the port engine. You can barely see the red hose at the top is water in from the port drive. The hose with the green stripe is water in from the thru hull to the Y. Then the black hose runs down, under the engine and to the port engine strainer that is next to the generator as you assumed. Goes from the strainer to the port engine water pump. Circle 2 is the port engine thru hull valve, Circle 3 is the stbd engine thru hull valve. Stbd engine is the same, the thru hull and the drive hoses Y together near the batteries. The thru hull hose again goes under the engine, to the Y and then to the stbd strainer. Strainer direct to water pump.
If you are really going to execute this I can get more pics but keep in mind that you still will have water coming from your drive, I dont think you can or should stop that due to drive cooling but I may be wrong.
