2006 volvo penta 5.7 wiring diagrams
i have been looking high and low looking for the diagram for my 2006 vp 5.7 osi-ef. when i pulled the motor for re-power, the wires for the crank position sensor got yanked from the plug. so now i have 1 of 3 wires connected. there are two wires that i need to put back into the plug but cannot find the diagram so that i know which goes where. here are pictures of what i'm working with. obviously this has happened before, the previous owner/mechanic used 3 white wires to fix the issue.
thanks in advance if you can help. looking to put the motor back in the boat on saturday and was hoping to get this figured out prior. not sure how easy it will be to reconnect this plug to the crank position sensor once the motor is back in the boat.
