RUSTY SPARK PLUG should I be concerned?
Trashman
Member Posts: 432 ✭✭✭
I have a 2004 350 mag mpi horizon. the boat is still on the trailer so I thought I'd replace the plugs. All the plugs looked good except one. It's the 2nd cylinder from the transome on the port side. Not sure if that's important. The others looked a little wet with gas/oil when pulled. It hasn't ran since November. What if anything does this indicate? Should I be concerned?
it would not be bad, but even the tip has rust.
So... Talked to previous owner via email and he never replaced manifold and risers in the eight years of ownership. I'm assuming they were never replaced by his po. I'm just going to replace risers and manifolds and be done with the guesswork. @Alswagg, any recommendations on aftermarket or pen or where to buy? I'm looking at Michigan motors package. Also. Am I ignoring anything by replacing the parts? Thanks for all the help so far.
I just ordered a dry joint exhaust manifold from MichiganMotorz for $335. That was the OEM manifold. Now I just need to find the time to install it.
What I noticed:
The second bolt from the transom on the manifold was not tight
There was moisture in the two center ports in the manifold.
Very Small droplets of water were on the shaft of the valves looking into the engine.
The exhaust flappers look fine and looking into the y pipe looks clean with just a small amount of pitting.
The elbow had loose flakes of rust packed into the small round hole. Wasn't packed solid but a good amount.
The 3" spacer looked like it had corrosion where it mates to the stainless steel gasket.
Thats all I got. Gonna post a few pics later. Gonna order parts tomorrow.
do I use sealer on any of the gaskets in between the manifold and the spacer/elbow?
Torque specs?
Heres a few pics of the old manifold/spacer/elbow.
