Help please with a 2004 342 performance question
I'm thinking of buying a 2004 Fiesta Vee 342 and
took it for a sea trial. The performance was less than I expected.
It has twin Volvo DP 5.7 liter Gi-e engines(280hp). The boat came on
plane quickly and nicely. I was surprised that a comfortable cruise was at
4000rpm and pushing 25-26mph. I though it would be slightly faster than
that with lower rpm's. If fact, the boat stated to loose plane at 3600rpm
and I thought that cruise would be at 3600-3700 but wasn't. At WOT I saw
4600 rpm and 34 mph. Again, I thought that both of these would be
higher. We were in fresh water with 1 to 1.5 waves. We never
trimmed the engines up at all. The broker representing the boat said not
do this on these size boats- its too **** the hydraulics and too much stress on
things. Broker also felt that this is the correct rpm's and speed for this boat. Are these results correct? If not, What should it be? Thanks for your help.
I'm
thinking of buying a 2004 Fiesta Vee 342 and took it for a sea
trial. The performance was less than I expected. It has twin Volvo DP
5.7 liter Gi-e engines(280hp). The boat came on plane quickly and
nicely. I was surprised that comfortable cruise was at 4000rpm and
pushing 25-26mph. I though it would be slightly faster than that with
lower rpm's. If fact, the boat stated to loose plane at 3600rpm and I
thought that cruise would be at 3600-3700 but wasn't. At WOT I saw 4600
rpm and 34 mph. Again, I thought that both of these would be higher.
We were in fresh water with 1 to 1.5 waves. We never trimmed the
engines
up at all. The broker representing the boat said not do this on these
things. Are these results correct? If not, What should it be?
- See more at:
http://rinkerboats.vanillaforums.com/discussion/1336/performance-help-with-a-2004-342?new=1#sthash.TO0e7JOR.dpuf
Best Answers
l-skynyrd
Member Posts: 178 ✭✭✭
Just one more thing to look at when the boat is out of the water is the props. Make sure they are the right size. The previous owner might have changed them to get a better hole shot which will effect the cruise and top speed. A call to Rinker or Volvo should get you the specs for what props came with the boat.You have to love the water....
Len & Robyn 342 FV Freebird
Dream_Inn- We were at 3/4 full on fuel, 4 adults all at or under average(no football linemen), and my 8 and 6 year old. Nothing crazy. As for the holding tanks, not sure their status. It didn't seem to have a lot of stuff. But as you know, you sure can hide a lot of stuff in the holds. Just had the boat pulled for a upcoming survey and the bottom wasn't all that bad. Had the bottom powered washed and after the survey Im going to take it out and mess with both trim tabs and drive trim and watch results.
Good luck in your search. Mike
campdavid, I have a set of performance figures for the 06 with the 300 hp and the Volvo XDP drives. My boat operated close to these figures, not quite as good but close. If you can give me an address I will send you a copy if you would like. These figures were generated on an '06 right here in Sarasota Bay. What drives does this boat have?
Tony
Salt Shaker 342
LG is sooo correct. I think it was he who changed his OSI's to OceanX's and found that it was a different boat.
I had the same crappy drives and put up with them for almost 7 years. They finally dumped on me (completely) during our loop trip in April this year. Had to have the boat trucked back home as a practical matter. Once back home I got rid of these very bad drives and did what LG did and installed OceanX's too. Like LG, I found that I now have a different boat. What a difference!
Bottom line be sure that what you are looking at is not equipped with the OSI drives. I will put up a photo of them so you will know for sure what you are looking at.
Tony
Salt Shaker 342
One more thing, the broker comment about not trimming the drives up makes it sound like they might be the OSI drives. I had the same advice for mine (2006 model).
But the real reason for that advice was because the bellows was a real weak point because they could not be made large enough to properly accommodate the shafts that run thru them. They would rub and wear thru them and then sea water would intrude and bingo, the gimbals would corrode on you and from there, things would get messy and expensive.
Trimming the drives up would all but guarantee this problem and bring it on even quicker.
I do not know what years Rinker was offering these crap drives but it might have included 2004 and for sure included 2006 because it sure affected me.
Tony
Here are the problem drives off the boat and destined for the junk yard.
If these are the drives you are looking at, they will immediately and forever give you headaches. If you purchase a boat with these drives, you should plan on replacing them as I finally did in my case. I also replaced the engines. The driving points for new engines was that the old ones had to be removed anyway to install a brand new transom shield that would accommodate the new design drives, in my case the OceanX's. And Volvo likes to sell drives and engines in sets so the price for the engines was not as bad as expected.
What I wound up with was a brand new boat in a 7 year old hull. Totally different boat and a performer too. This might not be a bad way for you to go if this is the situation and you get a price that would be attractive.
And all that new machinery comes with a two year warranty.
And the new engines that replaced my 280 hp ones are 300 hp.
And the new machinery is much quieter than what it replaced. Normal voices at 3600 rpms is all it takes to be heard.
RY, are these better?
LG
LG,
I should have waited to take that picture. The bottom has been painted since and it makes a big difference on how it looks. The paint that is in the photo is 7 years old. I painted the bottom because of the high salt content in our water here on the west side of FL.
I have a rule. When the boat is in the water at the home dock, which qualifies as "boating" I either take the boat on a trip, length of trip does not matter or, I put her back on the lift within three days. After about 5 days sitting still in this active water, things start to grow on the drives and other exposed underwater hardware.
I run my boat just about like you run yours and I think the original engines appreciated that. However from the point of view of those engines it was irrelevant since they were run thru the crusher at an early age anyway. They only had 900 hours on them. The new engines currently have less than 10 hours on them.
I hope my new engines break in and give me the same good service yours are. Right now I put her on 3600 RPM's all I can but I have to idle cruise and slow cruise quite a distance before I can put her on plane. With the new set up, getting her on plane is painless compared to the original set up. Very little bow rise and with "gentle" throttle use, she goes from displacement to plane in a heartbeat.
Tony
Salt Shaker 342
