Boat trial completed today, and boat is now named.
Lake_Bum
Member Posts: 1,121 ✭✭✭✭
My boat is a 2000 232 Captiva cuddy. I hadn't had it out besides the test drive, until today. Everything ran great, with the exception of a very small water leak. I found the source almost immediately, which was a slightly loose clamp on the hose that goes into the water pump. The boat has only 180 hours on it, so it has done quite a bit of sitting around, so I knew there was going to be a few bumps in the road. I already fixed the rusted Gimbal bearing, outdrive seals, and did a full service with new belts, and impeller.
I'll attach a few pictures of some of the upgrades I have done....
New name...
New name...
