Engine Stalls at low revs
Engine starts first time, leave engine running RPM approx.
600 after a while just stalls
Starts back up fine same again happens if I keep the revs
above 900rpm its OK
VOLVO PENTA 5.7Gi- G
Engine Serial No 4012215965
Out Drive DPS-A No 4202203870
But why only at low Revs, runs great above 900rpm
Yeah, 212rowboat has it right, you're starving it. If it doesn't bother you, you could always just adjust idle to keep it above the stall point (although I wouldn't want it to idle anymore than 700).
replaced IAC Valve and still stalls
low pressure pump 18psi. Manual says 8psi
high pressure pump 52psi Manual says 50 to 60 psi
i also checked fuel regulator and fitted the e Clip mod that Volvo recommend
but still stalls at 600 rpm
Going back the boat this Friday with a new Fuel Regulator
will keep you all posted
Guys
Plugs,Dissy,Rotor,Oil,filters,Leads all been replaced 600rpm is the correct speed, 600RPM on dash gauge also on Rinda Scan tool showing the same
someone will chime in that knows way more than me...I'm probably way off base as normal!
Replaced the arrester with a new one, and I have had the shore power connected, battery voltage is OK and alternator is fine.
Going the boat this weekend to have another look
Low Pump 10psi Old pump 18psi
High Pump 50 psi Old pump 54 psi
My thinking is to much fuel being delivered and flooding the Engine at low revs ?????
