350 MAG Mercruiser Alarm on Startup
Does anyone know if you should hear one or two beeps when you turn the ignition on from the audio alarm (I have no alarms when engines are running)? I have read it should be one beep and two if there is a DTC fault present but wanted to check with you guys to see what you have. I have a 2002 342 FV with 350 MAGs with engine serial numbers starting OM00xxxxx. Both engines have the same issues.
I haven't got any fault codes from a scanner but I am experiencing some RPM restriction to approx 3000 RPM on both engines which leads me to think this might be a guardian issue. Appreciate any help!
"Pipe Dream"
2002 Rinker 342 Fiesta Vee
2 x 350 MAG MPI Horizon Petrol
"Pipe Dream"
@davidbrooks using the scanner we have there are no fault codes while the engines are underway and being restricted at around 3000 RPM.
Thanks guys.
"Pipe Dream"
"Pipe Dream"
"Pipe Dream"
"Pipe Dream"
Thanks for the ideas so far guys. Any more please pass them my way. Cheers.
"Pipe Dream"
"Pipe Dream"
"Pipe Dream"
