342 air conditioner breaker
I have a 2002 Rinker 342 fiesta vee. When I'm on shore power, the small breaker will trip when the air kicks on sometimes. Other times it will be fine and not trip at all. It's not the big double breaker up top, only the little one. I thought maybe there was too much power draw but it trips with everything else on or off, doesn't matter. Also never does it when running on the generator.
I have times ones when I can leave for a week and the air will continue to run and be fine when I get back, and other times it will be off. Hoping to get this fixed before it gets real hot out.
I have the dual cable set up and have swapped the cables around thinking it may be one of the cables but it still does it.
I just replaced the shower power connection on my boat including the mounting plate that the locking portion of the cable connects. That did not fix it and is still acting up.
Not sure where to go next.
I have attached a picture of my breaker panel.
Thanks
Thanks
Any idea where the best to buy a replacement breaker is and also how many amps the breaker is?
Thanks for the help so far guys!
Not sure thou. Ill have to ponder on it.
15 amp I believe.
Can you put your hand on the pump to see if it's hot.
