oil consumption
MIKES342
Member Posts: 182 ✭✭✭
I have 27 hours on my 260 with 6.2 Liter engine. I used 1 quart of oil. I am going to change the oil on Tuesday. Is this normal during the breakin period.
Mike
In the old days, and in automotive applications, this vented to the ground and left a nice sheen on roads.. landlubbers didn't like that too much, so some used a catch can.. those catch cans caught the oil and provided proof to how much can slip past the rings in new, as well as old and worn engines.. a quart wasn't terribly uncommon, especially on larger displaced engines.. some smart folks decided it was better to burn the oil than smear it on roads, so they devised the pcv valve being inducted into the intake, and poof!!! No more oily roads, but instead stanky exhaust... Well, stankier, anyway..
Watch it, my man, and see if it doesn't abate.. it most likely will..
You've floated about the equiv of driving a car 1200 miles or so... If it is running good, just hang with it a while longer.. its really too soon to really know anything, even with an oil analysis.. though an analysis will tell you if its breaking in normally or if there is really high counts of stuff that you don't want... Just make sure and tell them its a new engine.
Mike the 6.2 is a great engine in that it is really strong. I believe that Mercury still "hand builds" them and the 8.2 Mag High Output. Regarding that quart of oil you mentioned some has gotten past the oil control rings as they seat and some is still in your oil filter. In my opinion your oil consumption is normal. I am sure the rate of usage will now taper off sharply. MT
Drew, that is an interesting explanation. It sound like you have to get lucky 8 times per engine. I am breaking in two newbies. Total of 8 hours so far. Starboard engine has burned zero oil so far. I put 250 milliliters in the port engine at my most recent run to top it up. I guess this is pretty normal. Yes?
Tony
Salt Shaker 342.
my 6.4diesel has 62k miles, and 1800hours of operation, as a driving to hours comparison, and not to attempt to compare engine wear...
the steady RPM's most use their boats at is not near the same as the constant fluctuations used while driving, but the engines are better built to sustain it..
2- oil burning is NOT a crap shoot, it is an inevitable trait of a new engine.. I'll go barney for you, because you may not have been paying attention while you were around watching your engines being built: cylinders are cross-hatched to create a microscopically abrasive surface for the piston rings to seal to the cylinder walls.. the valleys fill with oil on each and every stroke, and what is left over in those valleys gets burned during the power stroke.. it doesn't take long at all for the rings to marry to the walls of the cylinders- the cross hatching is done in a way that attempts to direct the rotation of the piston rings in a predictable direction, which is hopefully offset to one another.. most often, when the rings decide to 'seat', as in 'no longer spin around', they are off set, but sometimes they aren't..
3- 5 minutes? that is enough to kill an engine that isn't carefully balanced, and where you are demonstrating you really don't have a good grasp of what you're speaking... ever heard of a rev limiter? ever wonder why those are on there? ever heard of valve float? ever wonder why engines are limited below 6500rpm unless they have items such as beehive valve springs and carefully adjusted valves? (and this is speaking solely a portion of only valve train, there is a ton more on either side of that function).......... WOT (as defined by the rev limiter) is no problem on these things for five minutes- all it will hurt on a healthy engine and drive line is the economy.. take it to true WOT (no rev limiter), and it will self destruct in short order, especially if you decide to cross a wake, hit a chop, or do something else that alters the load on the engine..
