Engine won't start
So I went to the boat today with the intention of changing the oil. I started the engine to warm the oil up and it fired straight up as it always does with 1 turn of the key. I left it running for 10 mins to get it up to temp and it run without issue and got up to temp with no problem. I shut the engine down and went to get the oil from my car. When I got back I tried to restart the engine just to make sure it was fully warmed up before changing the oil. It fired up straight away but after about 5 seconds it started sputtering almost as if there was a lack of fuel and then died. I tried to restart and exactly the same thing happened, it fired up then splutters and the engine tried to rev up but it then dies. It did this several times but now it just turns over but won't fire up. The tank is about 50% full with fresh fuel (filled up last month). Engine is a mercruiser 5.7 efi. Plugs and leads were changed last season and cap and Rota the end of the season before. Any ideas?!?
