Won't get into gear
Hi guys,
I have a huge problem that I hope you can help me with. This winter I had a new Bravo III drive installed in my Rinker 232 Captiva with a 5.0 Mpi from 2006. The new drive was installed because the old one had a date with a rock.
Yesterday we went for a sail and after maybe a mile with 3,000 rpm the boat suddenly went up in rpm, but slowed down at the same time. I can start the engine, and it works fine, but I can't get it into forward or backward gear.
Have some of you got an idea on what the problem can be, or what to look after?
Thanks a lot in advance.
the coupler is easy to check... it always turns... so, fire up the engine and look at the input shaft of the drive... if it's spinning, it's good.
I will check the coupler and come back...
when the drive hit the rock the props also hit and took a lot of damage. Is it likely that the coupler could have taken damage at that point? (I don't know much about it). I just want to maybe have a reason for the insurance to cover that repair as well...
so... it's easy to move.... too easy?
you're gonna need to get that thing out of the water... look to where the shift cables attach to the foot (lower) and see if it simply jumped out of the little plastic lever thingy- it may be that simple... if it isn't out of the channel, then you're gonna have to man up and go to the heart of it- pull the plug and drain out some juice- stick a magnet to it if your plug isn't magnetized and see if you draw some metal....
you can turn the prop in gear (engine off), but you have better eaten your wheaties and you might want to have pulled the coil wire before hand (think throwing a prop on a early airplane) as you'll be turning the whole engine..... the lever that alters the output direction is a simple engagement of one of two gears (neutral in between).
transmissions, transfer cases, differentials (to a lessor degree) and outdrive upper and lowers may as well be written in Swahili braille so far as I'm concerned- they are black magic and witchcraft... sun gears, planetary gears, clutches, sprags, freakin' solenoids and........... let's just make it even more interesting by sucking water up through the thing via a shaft driven pump and cooling the engine too (alpha) while we're at it!!!! engineers do some amazing stuff.... i'm pretty sure they get high on the ganja in the parking lot before these idea's appear and manifest on the ar$e end of our boats.
from the engine side- if the engine turns the shaft while it is running, coupler working.
if engine off- and from the DRIVE side, if in gear and turning the prop by hand the engine CAN'T be turned- coupler bad...
i approached from engine side... you approached from prop side.. we both right.
