Rinker fv 270 wiring headaches
Hi all,
I hope you can help. I have recently acquired the above on a 2002 year and whilst I am happy with the boat, I am having a few gremlins which I am trying to resolve.
I am hoping you may be able to steer me in the right direction on the below 12v wiring weirdness!
Three issues have become apparent:
1. Engine hatch cover is slooooooow to operate
2. When engine hatch cover is operated, the navigation unit cuts out all together!
3. The mystery of the orange wire
What you need to know:
Our boat has the 2 battery configuration with a 2 way battery switch (batt 1, 2 or both) located on the side of the cockpit (not in engine bay). Having traced the wires, it appears the whole of the leisure side on the boat is supplied by a solitary red wire running from a splitter on the back of the starter motor (relying on the large wire to connect from the starter to the switch).
In addition, there doesn't appear to be a relay installed on the hatch lid and instead relies on the switch I the dash and rather small wires. There are some dodgy bits in the wiring so I am not convinced all is how rinker intended.
We also discovered a phantom orange wire which was disconnected just behind the alternator and also severed from the same connector on the starter motor.
It feels very much like the motor for the hatch is drawing way too much power and causing a voltage drop that the navigation unit is to sensitive to, but I am not sure.
So here are the questions for you if you can help!
1. Do you guys know if the hatch motor had a relay originally? It would really help to know as it may be that ours has been removed. A sketch of a wiring diagram would be super helpful.
2. Are your hatches super slow too? (Sometimes ours sounds like it is going to stop!)
3. By chance, do you have an orange wire coming from the starter still, and if so, where does it go?,
For extra credit...
4. I am thinking of running a further cable directly from the battery switch to the fuse board in the dash (to improve the available current) any reason not to? (Would naturally be from the switched Side of the batt)
5. I will probably install a relay irrespective on the hatch and will share but curious to know if anybody has done similar.
Thanks very much to all in advance, and I promise to post the outcome in due course for the benefit of others.
Kind regards
James
For extra credit...
Kind regards
James
http://rinkerboats.vanillaforums.com/discussion/3038/280-ec-wiring-diagram#latest
Drawings ar3 very helpful and better than the rubbish rinker published in the manual
To be honest, I can't get over the relative size of the cable feeding the domestic install - tiny!!!
Anyone have any ideas over the phantom orange cable? (On mine it is disconnected but used to be on same connector on starter as domestic supply)
"Pipe Dream"
2002 Rinker 342 Fiesta Vee
2 x 350 MAG MPI Horizon Petrol
I suspect that the original orange wire therefore may have been replaced - a shame they didn't remove the old one leaving it cut both ends instead!
That mystery is at least SOLVED!!!!
J
"Pipe Dream"
