Warning buzzer
martin1314
Member Posts: 36 ✭✭
Hi, I have small sounder/buzzer going off below the dashboard. You can see it when you lift the hatch within the toilet area and look back up to the underside of the dashboard.
According to the Manuel it's a warning sound but all the temp, oil pressure etc are okay.
I thought it was the inboard depth warring as it is jumping all over that comes with the boat so I disconnected it......... good move or not?
Martin
Martin
Best Answers
Handymans342
Member Posts: 10,375 ✭✭✭✭✭
Well if You had diesels you wouldn't need a buzzer. RLMFAO. Sorry couldn't help it -
93Vee Member Posts: 86 ✭✭
That is probably it. It may have debris on the transducer. I would follow the alarm sound/horn wires back to the dash and see if they go to the depth finder. -
martin1314
Member Posts: 36 ✭✭
Well........ its my first boat and so I'm guessing I'll need to feel a bit of pain............. but..... hopefully if the sun ever comes out and I get some good days, it will be worth it lolHandymans342 said:Well if You had diesels you wouldn't need a buzzer. RLMFAO. Sorry couldn't help it -
martin1314
Member Posts: 36 ✭✭
Cheers, I'll have a look tomorrow........... still no sun though lol93Vee said:That is probably it. It may have debris on the transducer. I would follow the alarm sound/horn wires back to the dash and see if they go to the depth finder.
