Motor run on
Have a 2003 180 br with a 3.0 merc cruiser. I am having trouble with run on But it doesn't always idle the same sometimes 900rpm sometimes 650 rpm at idle. Will die ok at 650. I don't see any linkage problem. Anybody have a idea what might be problem
a really hot engine will ignite on and due to compression, which is what a diesel does... it won't do it but for a second or two, though.. to truly 'run-on', it needs air and a hot spot in a cylinder to ignite..
