Bad Coupler?
Last weekend we were cruising along just fine when i made a turn and the port engine increased in RPM's but the boat seemed to slow down and start to lose plane. I stopped, checked everything, all gauges were good. Went to take off and boat seemed a little sluggish but nothing terrible trying to get on plane and then when i went to raise my trim up to level out the port engine again revved up really high but it wasnt picking up speed. After putting for a few minutes and thinking about it i tried one more time and the boat ran perfect and the RPMS were fine.
This weekend the boat seemed to do the same thing again and i began to think maybe my trim was acting funny because it almost sounds and acts like just that one prop is cavitating, but that all seems to be working fine.
I then got it up on plane without issue and it just seemed to run about 400rpm more than the starboard engine and they are usually at the same RPM. I checked the outdrives while running and they both were level with one another and from what i could visually check seemed ok. I havent hit anything so i dont believe its a prop issue.
I am now worried that it may be my coupler going bad. I didnt smell any burnt rubber or anything but thats what it seemed to be pointing to and im worried that im going to be without my boat for half the season to get it repaired.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
monopoly in that sense. I had both outdrives pulled and checked all bellows and such last fall. I hope I can get by at $1300.00 for just this. My friend told me my engines appear very easy to pull as they just need to come straight up and there is lots of room behind them. Hope that's the ca
