just can't catch a break!
so today was the maiden voyage of my re-powered 06 250ec and it ended on a sour note. it appears that of all the things i didn't replace, the power steering pump started whining and the steering got real jerky. at one point i think the power steering pump locked up and caused the belt to smoke a little. hopefully it didn't damage my new belt but the puff of burnt rubber smoke that came from the bilge tells me that it did. thankfully i was only about 2 miles from the boat ramp and we limped it backed to the trailer on it's own. with a serpentine belt, i certainly wasn't going to push it more than necessary. the pump only whined when you turned the wheel at lower rpms so i kept it about 1200 and crept back to the trailer. hopefully a local shop that is really good at alternators and water pumps can rebuild this power steering pump. they're good and stand by their work, so 75 bucks vs 300 bucks for a new one sounds good to me.
i almost had the power steering pump and the alternator rebuilt but figured they worked, don't fix it. well, it wasn't broke, but it appears to be now! while the pump was off for the rebuild, i did drain the old fluid and replace with fresh. i did notice a slight whine to the pump while in the driveway. didn't think it would only last 20 minutes at 3500 rpms.
might as well replace the alternator while i have the belt off again. no sense it letting that leave me stranded after everything else i've replaced. looks like i will be at 100% new next time it hits the water.
when you replaced your pump, did you use an automotive pump or marine specific? they look very close to an automotive pump in the pictures on the internet.
