running the air conditioning on the trailer
do they make a plunger type attachment for the through hull water pickup ? i need to trouble shoot my air conditioning and would like to do it in my driveway on the trailer if possible. when on the water this past weekend, we verified that the water pump is working and the fan comes on but not the compressor.
http://www.amazon.com/Alloy-Marine-Products-FAKE-A-LAKE-Inboard/dp/B00280COZO/ref=pd_sxp_redirect
how long should that control wire be? I'm sure I'll need the control unit connected in order for it to function properly. Not sure my HVAC guy is going to want to crawl into the aft cabin, even though it's a lot cleaner then most places he goes. It is tight in there to try and work.
what really stinks, i had a bad o-ring in the low pressure side of my dual gauges. if the o-ring would have been good, i would have realized that the system was holding vacuum without having to take it out! after i used the hand pump and it didn't bleed off, i started investigating my dual gauges and replaced both o-rings in the high/low valves. holding steady like a champ now. oh well, just another aspect of our new boat that i got to figure out. i'll let ya know how it goes once i get some r-22
dometic marine air 7000
the high and low pressure fitting where just normal schrader valves. my residential HVAC guy put his gauges on and carged the system. it has worked just fine since.
