Throwing a code, same rpm/speed, every time, like clockwork. Help on a holiday weekend
i know there's a whole lot of different thing to cause the 2 beeps/minute alarm, but maybe someone has seen something similar. My tach has decided to be erratic this year, so I can't give RPM specifics, but at exactly 35 MPH, I'll get the 2 beeps/minute, every single time like clockwork. I can slowly creep up to 35, or I can go WOT off idle, and at 35 MPH, I get the tone. The boat starts and runs great. It'll even accelerate up to its normal 55 mph speed with no issues, but the tone is there every time. I just drove it back to the marina at about 34 mph for about 10 miles, and no tone.
I cant think of what it would be. All my temps and oil levels showed to be good. I can't imagine a sensor to make it go off at the exact same parameters every single time. I tried every marina to get someone to scan it, and they're all too busy.
Thoughts?
Thoughts?
Post edited by 69fastback on
i think low is 4.8vdc and high is 5vdc- so the delta is tight.
maybe hit the points with sandpaper or wire brush? make sure it's well seated?
seawater pressure will also trip a 2bp/mn... and kinda makes sense as again- RPM to speed is about same... weird that 34 doesn't trip it. stupid question, but does it continue to beep above 35? that sensor could likely be recovered with a good cleaning, too.
i'm thinking any of the other 2bp/mn alarms you'd notice, as they trip guardian and reduce power to 90%.
edited to add:
if you run it to 35 and get the alard trimmed up, trim or tab down if you have them (dropping speed by drag not throttle) and see if it remains... you can do the opposite too by approaching 34 or so tabs/trim down and lifting trim/tabs until you pass 35 and see if it alarms..... if it does this would all but eliminate the TPS.
Once it trips, I get the tone until I shut the engine off and restart it, regardless of speed.
So, I don't have trim tabs, but I did donas you mentioned, and I took it to about 33-34 with the lower unit trim all the way down, and I trimmed it up tongain speed. It seemed to take a little longer, but it eventually gave me the tone.
I also started off idle and went WOT, and with no trim adjustments off full down, it tripped as the boat accelerated through 35.
i do impeller replacements every other year, and last year was no replacement year, so the one in there has a full season on it. ~30 hours.
2003 232
350 MAG
Bravo 3
it's like most pressure sensors- has the hollow bodied threaded slug with the blank 'hole' in the end... could be it's obstructed... could be it's just flat not working. ohm it out?
Two Alarm beeps every 60 seconds are for:
1.) Faulty cam,
2.) IAC,
3.) MAP,
4.) MAT,
5.) knock sensors.
6.) open/short in the engine cooling temp circuit
7.) open/short in fuel injector wiring circuit,
8.) open/short in oil PSI circuit,
9.) open/short in exhaust manifold cooling temp circuit,
10.) open/short in sea pump circuit,
11.) open/short in throttle position circuit
i was wrong- the low pressure on your engine is constant beep.
how old is your fuel? is it recreational fuel or ethanol laded?
Cam sensor - I would think it would run poorly
IAC - don't think so. It starts, idles, and runs fine
MAP- again, don't think so
MAT- ???? Stil, doesn't sound right
knock sensors - would that put it in limp mode? It doesn't seem to be, but not real positive
5-11 pfffff, I'm not sure what actual symptoms would be.
the IAC just had to be out of range at whatever engine speed- doesn't have to be idle, and the TB can hide a lot of issues with it during operation.
I suppose youre right about the IAC and TB. It just seem like the "normal issues" associated with them, but that definitely doesn't rule them out.
l need to make my radio louder in order to drown out the beeps. Lol
