Kohler 5E generator - how to get engine data via SmartCraft or N2K?
LaRea
                    Member, Moderator Posts: 7,920 mod
                    Has anybody successfully hooked up to a Kohler 5E generator to get engine data via SmartCraft or NMEA 2000?  How did you do it?
I know @Stodge and @Dream_Inn discussed it a couple years ago, and I've searched far and wide on the webbynet, but I've found nothing.
After further research, I realized that my generator is a Kohler 5ECD, not 5E. It actually has a SmartCraft plug that I never knew was there!
The Operator's Manual mentions a P-19 plug. I started removing panels from the sound box, and eventually found it. As I'm facing the control panel on the front of the generator, the plug is at the far back right corner.
I temporarily attached a SmartCraft Y-cable from the genny to the helm SmartCraft junction box. On the VesselView, I went to the setup page and enabled the generator, and I can now see a screen where data should appear. However, the values are all blank.
Best guess: the other end of the SmartCraft Y-cable needs a terminator plug (which I will have by next weekend).
http://www.baylinerownersclub.org/index.php/forum/technical-discussion/26979-bayliner-vessel-view-and-water-tank-sensors?limitstart=0
Merc's tech support emailed me a diagram for hooking up a Kohler generator to a VesselView 5. It's the same diagram that has been circulated before:
The plumbing is totally different on the VV 702, but I bought the two adapter cables (889280T01 and 84 889278T01) anyway to see if I could make it work. There are two places where the 887278 can be inserted, and neither one worked.
So, @Dude_Himself - don't buy cables yet!
@Dude_Himself did you ever get it to work?
