Rinker 290 FV Horizon 600 Windlass stopped working - ideas?
Well as luck would have it (because we generally don't go out too many times without something breaking....) our windlass stopped working this weekend. The rope got twisted and caught under the gear which caused the windlass to stop as it will normally if it gets in any sort of stress. The circuit didn't trip. Normally when i'm pulling the anchor up if it gets stressed it stops and I just back off of the it with the down switch then go back to raising it with the up switch. This time after getting the rope untangled up or down don't work. The motor never showed any signs of grinding or smoking, etc that would indicate that it burnt itself up. When i try to use the switch up or down there's just nothing- no noise no nothing like it's not even getting power. I read that often the solenoid will go out, but i can't find it in the anchor locker (of course I can't see much either except for the wires leading from the wiring harness up to the windlass motor box through the deck locker. Do windlasses always have a solenoid? Where else would it be? I can try to insert a phone camera through the tiny hole they give you for access (thanks Rinker, lol) under the mirror to look for it again, but I couldn't see or feel anything other than the wires up in there.
I thought about replacing the up/down switch on the dash or the circuit breaker, but I'm not sure that will do any good if it's indeed the solenoid.
Help! :-)
Thanks!
Help! :-)
Thanks!
I've pressed the test button and pushed back in the little arm thing about a dozen times with no luck.
So so on the windlass I loosened the nut and was about to turn the gear teeth that the rope and chain go through freely. I was not able to turn it though if I tightened the nut back down which I wouldn't think you would be able to do. It doesn't have free fall- just up or down.
I wonder ifi if I should just order a switch and circuit breaker new and hope that fixes it. I'm not very good with a volt meter- I don't really know what to put to what etc...
thanks again for tge the thoughts and any future thoughts guys!
Also, look in your battery switch housing, if I recall I have a "poppable" breaker there. See if one of the white buttons has popped.
Thanks!!!!!!!!!!!!!!!!!!!!!
