Changing raw water pump impeller on my 270 - Mercrusier Horizon 350 Mag, Bravo III
I was out the other day and was letting someone else drive my boat and we ended up in some shallow water. Long story short, I was up on plane the next day and the temp alarm went off. I am pretty sure it is the impeller. I think I sucked up some nasty stuff and ruined it. It seems like typical impeller symptoms... When I am putting around it is fine but when I get up on plane and the impeller is forced to suck water it overheated. I am going to change it myself (this is my first), any tips along the way?
"Mosi on Dahn" 2003 Fiesta Vee 270
Hoses are different sizes.
I agree with Renee. Unbolt the pump entirely and pull it out a bit, then loosen hose clamps (much easier to get to that way).
http://www.smwebhead.com/phpBB3/viewtopic.php?f=11&t=7491&p=72754
Good luck.
Well, I pulled the pump out and the old impeller looked good. I obviously changed it anyway. I will put it all back together tonight. It only overheated once while I was on plane. It may be possible that I sucked a bag against the intakes on the outdrive. I'm going to put it back in and run it to see what it does.
I read that scoring on the back plate can cause the impeller to lose suction but mine doesn't look too bad.
Old Impeller
OLD IMPELLER
Ouch!
I already have it back together and will test it out soon.
If it's single pickup, you might have a partial blockage of the hose inside the outdrive. The fitting at the transom can get corroded, reducing the water flow. That would make it more likely to get stopped up by debris.
It is a single pickup through the drive.
I actually just had that fitting replaced a week ago but it could still be clogged. We had some flooding in Pittsburgh this weekend so my boat is still on the shore and haven't been able to test it out.
