Looking for ways to clean up all the connections to my battery
I have a small outboard and the wiring to the battery does not look very neat and tidy. There are not many electronics on the boat : electric starter with combined key and push in choke, navigation lights on bow and stern, horn, radio, bilge pump. All of the connections attach directly to the battery with two wing nut connectors. There are four positive connections stacked on top of one another and two negative connections also stacked. There are also two inline fuses very close to the battery. I would like to change the wiring so that there is only one positive and one negative connection on the battery. This would reduce the chance of connecting the leads to the wrong terminal. I am also thinking it would be a good idea to disconnect the battery from the wiring when the boat is sitting on the trailer in dry dock storage. In addition, the battery removal for charging at home would be easier since the dry dock I am renting does not have any power connections available. Does anyone have any input on weather splicing all this together is a good idea? I think a water proof switch panel might be the way to go. Something like this http://www.defender.com/product3.jsp?name=blue-sea-systems-weather-deck-waterproof-circuit-breaker-panel&path=-1|328|2290000|2290003&id=589764 might be a big improvement.
Best Answers
howardrams Member Posts: 223 ✭✭✭
rkinross, so you're talking about wiring your simple boat more like a cruiser. Short of going to all that work, I would recommend recrimping most of those ring terminals to make sure you have good connections, and label each wire (radio +), (radio - ), etc. Then wire tie all the positives into one bundle, all the grounds into another neat bundle, and that should help prevent people from mixing up the pluses and the minuses. maybe wrap some red electrical tape around the plus bundle and black tape around the minus bundle. I'd still go with the individual ring terminals on the posts rather than just spicing them all into one. Various electrical codes don't recommend crimping more than one lead into a ring terminal, or butt splicing, etc.
Otherwise you go with your idea of a single ground buss mounted somewhere for the negatives, and a power distribution panel with individual breakers/switches for the accessories, wired through a main battery switch if you want to be able to turn off all power at one point. But then you'd probably still want to leave those heavy starter motor cables going direct and just run the accessories through the switch panel. -
LaRea Member, Moderator Posts: 7,844 mod
I am thinking of doing something similar. I want to get a 4x4x2 PVC junction box ($5 at Home Depot) and mount a terminal strip inside it. Multiple wires go in to the terminal strip, and two wires come out to the battery.
So you would have two wires at each battery terminal: the thick one to the load, and a smaller one to the junction box.
Regardless of what you do, you should definitely re-wrap all of the positive wires with red electrical tape or shrink-wrap. Black wires going to a positive terminal is confusing. -
Willhound Member Posts: 4,218 ✭✭✭✭✭
@rkinross, I had a smaller boat for many years with all kinds of accessories. VHF radio, stereo, sonar/gps etc. I installed one of these:
https://www.bluesea.com/products/5025/ST_Blade_Fuse_Block_-_6_Circuits_with_Negative_Bus_and_Cover
One power wire and one ground wire to the block, and then all accessories wired to the block each with its' own proper size fuse.
I used a separate battery for a trolling motor, but for heavier connections from a single battery you can also use these:
https://www.bluesea.com/products/2151/Dual_MRBF_Terminal_Fuse_Block_-_30_to_300A
Keep your eyes open for sales and you can buy both for around $20."Knot Quite Shore" - 2000 FV270 (Sold)
2 heavy cables 1 black and 1 red - goes back to the outboard (no fuse)
1 red/(really orange) back to bilge pump
1 red with black tape on the loop connector - destination unknown
1 red connected to 20amp fuse then spliced to another red and another green - destination unknown
1 red connector has 3 splices
first splice goes to 20 amp fuse and continues to red wire
second splice goes to another 20 amp fuse, then to a 2 inch brown wire and ends with a blunt white connector holding a green wire that goes back to the negative bundle (i am really confused by this because it does not look like the blunt white connector connects the two wires it is holding. Also I do not understand why the positive red wire would be going back to the negative terminal via the green wire.
third splice is a green wire that goes back to the stern - destination unknown
I have tried to follow the wires up to the ignition key but the colors change up at the connections to the key so that does not help. The key also has a built in switch to engage the choke when the key is depressed.
If you made it this far, here is the question. How do I determine the proper placement of the connectors onto the battery? I have a multimeter and know about continunity testing so I was considering placing the probes on each of the ring connectors while they are disconnected from the battery. If I get a reading, the circuit is complete so the red probe must be positive and the black probe must be negative. Am I on the right track here or should I do more research?
I got a pair of pre-made #4 battery cables and ran them from the battery to this Blue Sea Systems dual power post mounted on the transom near the battery:
https://www.westmarine.com/buy/blue-sea-systems--dual-powerpost-cable-connectors--P009_273_004_505?recordNum=1
Some of the accessories are attached directly to the posts. The others are fed by this 4-circuit breaker panel:
https://www.westmarine.com/buy/blue-sea-systems--st-blade-battery-terminal-mount-fuse-block-kit--16016206
Here's a "90% done" photo. The battery now has only three connections: charger, starter motor and accessory panel. It's safer and less confusing.
