Black foam coming from port side outlet, what are these two outlets?
Foam coming out of this port side drain outlet, what does it go to?  I could not find what these two outlet are in any of the manuals.
    ?shower sump? Run some clean water in the shower and watch the hole.
  • LaReaLaRea Member, Moderator Posts: 8,003 mod
    Or forward bilge pump.  There's a separate bilge under the mid-cabin, not connected to the engine room bilge.  It has its own pump.  Could some soap or other cleaning product been spilled into the bilge?
    @LaRea is correct, one is the mid-cabin bilge pump and one is the shower sump. Check under the aft cabin couch,  remove the floor flange and look inside to check bilge pump. Then, under the port side couch cushion there is the shower sump, that needs to be cleaned once in a while depending on use.
  • ChuckvecChuckvec Member Posts: 24 ✭✭
    Thanks everybody! I knew you all would know.  I will follow bry1429's advice and check both systems.  C
