Trim limit and indicator pucks
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
i've had constant problems with the limit and indicator pucks. The indicator one works on/off/ poor readings. The limit one does not 'stop' the drive, it just goes untill it reaches its limits ( pumps do not turn off).
Do these go bad or is it more an adjustment issue. Been fussed with to adjust over the years and it never lasts.
These a pita to DYI to replace? Any thoughts on the problems?
thx.
thx.
they are mapped- the little ticks must be aligned. problem: there are multiple 'ranges'. for speaking terms, there is a high at noon and a low at five- common sense would say it goes from low back to high, but.... that would just be common sense, because they don't... they go back to high at five and in a split mil from 5 o'clock.... but wait!!! there's more!!! common sense would dictate the next low would be 5 hours away, but... that would just be common sense.. the next low is at something like 8... and it works the same- a split mil from low to high... and the next low is- well, you get the idea...
it's almost like they should be printed "if you've this much ram measured from the eye to the stancion seal, use the 'high' found at X o'clock"... but no... you get to fish for it.
it's a two person job. period. unless you've laid out a line, as Kidd Rock say's "from here to memphis" and have little concern for your nasal cavity and heavily invested in that energy source, it is a TWO MAN JOB. with patience galore. both of them- the limit and the gauge... in order to get to them it's absolutely best to have the drive off. they're a PITA even then. and, there is a difference between the limit and gauge 'pucks'.
i r r i t a t i n g.......
but once they're done...... they're done.
thanks for the adjustment tips Drew!
