Upgrade from 250 single 5.7 to 280 twin 4.3s?
Hello,
We currently run a 1988 Fiesta Vee 250 5.7 on Lake Michigan. We travel when the weather is right. We have radar, charts, plotter, ect.
I'm considering upgrading to 1994 Fiesta Vee 280 twin 4.3s. The reason is for redundancy in the event of a motor becoming disabled. My fear is becoming disabled and ending up on the rocks while waiting for sea tow. The additional motor would eliminate that concern. The extra space and size would be nice but not necesarrily a factor in the decision.
At this time we don't intend to run across the lake.
Our initial goal is to go north to Sturgeon Bay from Milwaukee, around the Door Peninsula and back to Milwaukee.
Can anyone offer advice or thoughts on this senerio?
Thank you
Thank you
David H - Milwaukee
1988 Rinker Fiesta Vee 250
1982 Ski Nautique 2001
Best Answers
aero3113 Member Posts: 9,415 ✭✭✭✭✭
I would think the 280 with twins would be a better ride also, the extra weight spread across the stern will make it more stable.2008 330EC -
F1100 Member Posts: 292 ✭✭✭
my 300 with twin 5.7 can take some serious waves at a good clip. And can cruise on plane at about 25 mph
1993 300 FIESTA VEE TWIN 5.7L ALPHA GEN 2 -
Cableguy Greg Member Posts: 5,049 ✭✭✭✭✭
There used to be a 280FV with 4.3's at my marina. I rode in it years ago and it ran great on the river. It had the Alpha 1 drives with 4 blade props.
Go Steelers!!! -
zaverin1 Member Posts: 1,672 ✭✭✭
4.3
1.1 prop around 24 to 26 mph abs 3400 rpm
the wider the beam
much stable the vessel becomes -
at max speed its about 4500rpm and 37mph, at 25mph its at about 3300rpm or so
yes the 300 is a nice size, not too big, but big enough to handle water, and be comfortable on.
even fully loaded the boat comes on plane pretty easy
at 24mph or below, it wants to come off plane
I'll take the 280 for a spin when I get a chance.
aero3113 I would also think it would be quite a bit more stable than the 250.
Zaverin1 are you running 4.3s or V8s. I'm curious about the gph.
F1100 the 300 certainly look tempting.The size does however seem like a logical step from the 250. With the V8's at the 25 mph are your turning 3500 rpm? (at 3500 my 5.7 is 12 - 15gph.)
