Anyone have a how to on adjusting throttle linkage on 350 mag mpi? Thanks
Please post a link or download.  Thank you!
My starboard is getting stuck up around 1500 rpm and i have to wiggle throttle back to get rpms down.  This is causing some hard shifts when docking and to much speed.
  • rasburyrasbury Member Posts: 8,788 ✭✭✭✭✭
    So you need to adjust your lower shift cable? You may have a cable going bad. There is a great you tube for the lower shift cable, try bravo lll lower shift cable install...would not think you would have anything to adjust as nothing should have changed...
