DOME LIGHTS WITH A SWITCH
HELP PLEASE! NONE OF THE DOME LIGHTS WITH A SWITCH IN THE CABIN WORK AND THE LIGHTBULBS ARE GOOD. WE HIT GIANT WAVES AND THINK IT MIGHT HAVE JARRED SOMETHING. I TOOK THE DASH OUT AND COULDN'T SEE ANY OBVIOUS CAUSES. NOT SURE WHAT TO DO NEXT OR HOW TO ACCESS THE FUSES
    Look at your electrical panel - the 12v side. First, find the breaker for your cabin lights and flip it off and on in case it just needs to be re-set. If that doesn't work open the panel and look at the back of the breaker in question to see it the ground wire(s) look loose as the grounds often work loose.
